#6784 10/24/03 12:30 PM
pe1932c Offline OP
I have a broken spring from my 32 trans. This is the spring that is exactly the same as the other 3. Hopefully I an explaining properly. Where can I get new ones?
paul orednick
305 canal st
lemont Il
60439
#6785 10/24/03 03:44 PM
Can you be a little more specific?
#6786 10/24/03 08:55 PM
Are you referring to the springs in the freewheeling unit? The freewheeling unit bolts to the back of the transmission and has the lever on the shaft coming from the top. If it is a freewheeling unit spring then good luck. Just put it back together and lock out the freewheeling unit. They are dangerous to use anyway.
#6787 11/13/03 07:59 PM
pe1932c Offline OP
Thanks to all--I found the clutch springs in the NEW filling ststion catalogue--There are actually 2 sizes --I needed the large and Filling Station had both!
paul orednick
305 canal st
lemont Il
60439
