Posts: 2,157 |
so, any suggestions to explain why suddenly this week, the roadster's boiling over on trips over ten miles?.. only clues are that: 1. I think I'm losing the 50/50 coolant as I drive, as I start with it full when cold, but after 10-20 miles, the gauge starts to rise (it normally barely registers)... 2. the overflow is hot & foamy (foamy green coolant, not the beige foam that would suggest oil contamination)... 3. afterwards, I can add coolant to the system... 4. I don't see any obvious leaks anywhere (no, jyd, I haven't put a new fs core in yet...was trying to pooch it until next spring to save some bucks for now...so there's still that patina corrosion on this core)... 5. no other issues, such as steam from the exhaust or loss of power, etc... any help would be appreciated...  epi
Hi chevrolet, If I remember correctly your vehicle had sat for a very long time before you received it. I would wager that debris has been loosened in the cooling system and has relocated in the radiator. Suggest you drain and "back flush" and observe what if anything comes out.
Posts: 2,157 |
ray, that's a very good point...it had gone about 200 miles in the previous 20 years...I've put 500 miles on it just this year... I'm familiar with back flushing on modern iron, but what's the best way to do it with this old boy?..  epi
I would disconnect both the top and lower radiator hose. Flush the radiator in BOTH directions and do the same for the block. If it has a thermostat installed remove it for this procedure. You would hope to see some BAD stuff coming out of both the radiator and block.
Posts: 2,157 |
ray, thanks...I'll give it a "shot"...  epi
First tighten the water pump nut a little. Even though it will not leak water it will draw air past the packing and seals into the block causing foam in the coolant.
Posts: 2,157 |
chip, thank you for the tip...I'll try that first to see if the problem abates...the flushing still sounds like a good idea to get the system clean and working well...  epi
I did not intend to inhibit you from the flush. It is a must every two years when you change the coolant. It is highly recommended in every vehicle to change the coolant every two years. An exception may be the new extended life antifreeze factory filled in todays vehicles. But I would never go past the five years that they claim. Also flush the brake fluid [ed. in your '36 and later Chevy or '39 and later F&$#]every two years and you will eliminate problems with corrosion and leaks. Maybe I should write a book on cooling system and brake maintance. The company I use to work for in the Automotive chemical group was and probably still is number one in brake fluid.
Posts: 765 |
Cooling problem possible solution.
May years ago I had a boil over problem with a 35 Standard Sedan. A long time-older VCCA member Everett Cooper gave me some advise. This was a solution that he used in the 30's fixing cars at a garage. I followed his advise and never had another problem. When I told him later that I followed his advise with no further problems he just grinned and smiled. The following may work for someone else.
1) Empty entire water cooling system. Drain from the lower radiator hose. Remove any thermostat. 2) Re-attach the hose 3) Here is where I hesitated. But after explaination I understood. Pour in to radiator 1 to 1-1/2 gallon of mineral spirits. Available at your local hardware store. Do not over fill. 4) Start engine. Let run for 10 minutes. This will circulate thru the cooling system and desolve grease build up from the water pump. 5) Shut engine off. Remove lower radiator hose. Drain liquid / sludge. Please be environmentally friendly with waste. 6) Repeat steps 3 - 4 - 5 7) After cleaning with two flushes now mix a solution of 50% Detergent ( TIDE LIQUID without bleach ) and warm water. Please mix to fill system. 8) Check that the hose is connected, Fill radiator 3/4 full with the detergent and water solution. 9) Start engine and let circulate. Run at idle for 10 minutes. 10) Shut engine off. Remove lower radiator hose. Drain liquid. Please be environmentally friendly with waste. 11) Repeat steps 8 - 9 -10 12) If you still are removing a lot of dirt repeat steps 8 - 9 - 10 one more time. 13) After the detergent / water solution is complete. Check to make sure all hoses are back in place. 14) Fill radiator with clear water. 15) Let run for 10 minutes at idle. 16) Shut off engine, drain from lower hose, reattach hose. 17) Repeat step 14 - 15 - 16 until water is clear. 18) Check packing nut for packing and ample grease. 19) Fill with your proven personel choice of coolant. Some prefer antifreeze, glycol, alcohol. I preferred plain water in a non presurized system.
As I said earlier I listened to a person that experienced these problems when the cars where daily drivers. I never had a problem again. In fact the car always ran cool. I have used the 5/8 hole in a sheet of brass in place of a thermostat. This is held in place between 2 housing gaskets. It is a time consuming project. But, it solved my problem. I know this was long. But I think alot of people could benefit from this process Good luck.
Member 45+ years, been around since the beginning !
Posts: 2,157 |
chip, don't worry, I didn't take your message that way... how tight should the packing nut be?..I tightened it one complete turn, but was afraid to go further...didn't take much force to tighten, but then again, that 1" wrench is mighty long... I like this as a possibility for my problem, as it started after I turned down the grease cup...maybe I forced some old grease out that was helping the packing's seal?..  epi
Posts: 2,157 |
ken, thanks for taking the time to share this process with us...I'm going to work through chip's packing nut suggestion first to see if it solves my problem...hopefully it does...then I'll be ready for a thorough cooling system cleaning...  epi
Posts: 2,157 |
how tight should the packing nut be?..  epi
Posts: 3,542 |
VCCA Son, thank you for a great post,  a couple of questions for you and others: Are there any problems with getting loose stuff where you don't want it? :confused: How much water does the '32 hold? :confused:
Posts: 11,162 |
That is a good question. I played with the one on my '28 for a while. Right after I bought the car I decided maybe I should repack the water pump since I remember having to do that a lot with my Model A **** back in the early 50s. The pump would drip several drops of coolant when it was shut down after being driven for a while. I noticed the shaft housing bushing still had quite a bit of threads showing, I unscrewed the packing nut and slid it to the front of the shaft cleaned the threads,but didn't take any old packing out and wrapped a round of rope packing around the shaft, tried to start the nut and it barely started, I took the new packing out and started the nut back on, tightened it to where it was snug, with the engine idleing so that I could see if the belt was going to slip, in case I got the nut too tight, only about a couple of turns tighter than it originally was. It has not dripped more than a drop or two since and I haven't had to add more cooling than just replace the expansion loss (about three inches down into the radiator neck). I have only tightened it a couple of pulls (1/12 of a turn each pull)in the last 600 miles. I change oil every trip or 500 miles and check the packing nut and turn in the water pump grease cup a round or so, I have been useing the cream colored Lubriplate waterpump grease. I believe that having good clean packing properly tightened and useing a good waterpump grease will keep shaft wear down and also keep the pump from sucking air into the cooling system, which I am convinced causes many problems of over heating from foaming and burping coolant out the overflow.
P.S. I see that B.B has decided to censor out some bad words including F@RD, Ha!
Kepi, I would be very careful about putting mineral spirits into a cooling system. It is flamable and not sure how to dispose of the waste properly. I also don't think the hoses are fully compatible with mineral spirits. It will clean out any hydrocarbon (oil, grease) contamination. I would rather try either a caustic type cleaner (also for grease and oils) (like the old solid draino). They are agressive toward aluminum so are not used in modern cooling systems but are fully compatible with our old systems. Disposal should be much easier to deal with. The cautic based cleaners will not do much with corrosion products (like rust) or scale (like from hard water). Acids (mineral or organic) or chelating agents are better for them. Modern cleaners use organic acids (like oxyalic or citric) or chelating agents as they are not as agressive toward aluminum as the mineral acids (muriatic, sulfuric, etc.) I use dilute muriatic acid followed by a few bicarbonate flushes, followed by a couple of clean water flushes. It works well in our old Chevys but will dissolve some of the corrosion products that seal some of weak spots on our old radiators. Therefore, it is not uncommon for a few seeps or leaks to be found after cleaning.
Posts: 2,157 |
chip, thanks for the cautionary... the roadster foamed a little after the packing nut tightening, so I guess I'll try tightening a little more...other than seizing the water pump shaft from excessive frictional force, anything else I should be concerned about as I continue to crank the packing nut down?..  epi
Posts: 11,162 |
I got quite a "kick" out of the 1928 Repair manual, It reccomended using LYE (Sodium Hydroxide) to flush the radiator I am assumeing to get rid of the waterpump grease and other "oily' substances and acidity that contaminated the cooling systems back before good coolants with corrosion inhibitors were in common use. I don't guess there would be a problem of flushing that chemical down the sewer drain would there Chipper? Isn't it still a component of drain cleaners?
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Lots of good cleaning ideas! I would also recommend checking for compression leaking into the cooling system aka leaking head gasket.This also can cause foaming and overheating.
Posts: 2,157 |
m006840, thanks for the suggestion...I've discounted that myself, as I've not seen any coolant contamination of the motor oil, as I would expect to see if the head gasket is leaking...  epi
Posts: 210 |
Hi Chevrolet, I chaced an overheating problem for a few months and finaly got it resolved. Rather than go through it again here, head for " Engine bottom noise" Aug 27,2002 and take a look...It may help. Good luck
Posts: 2,157 |
leo, thanks...I'll check it out...  epi
Posts: 2,157 |
dog, yeah, I know...but you know me...I don't even want to THINK about that possibility...  epi
I wouldn't discount the head gsk so quickly-It not only seals the coolant in, it also seals the air in the combustion chamber.Because you can,t see coolant leaking does not mean compression is not leaking out,perhaps into the coolant.You can try looking into the radiator with the engine running and look for air bubbles.If you want to eliminate the chance the air is coming past the water pump try pressurising the cylinders by adapting an air fitting to a spark plug.You will have to check each cylinder indivdually while watching the radiator for air bubbles.Use a regulator on the air line to control the pressure to what normal cyl pressure should be.Good luck!!
