#6397 09/23/03 05:47 PM
any tricks for keeping the gas fumes down on the '30?..
a small amount of gas routinely gets out through the small vent hole in the center of the gas tank cap, vaporizes, and gives me a big headache... :(
any suggestions would be appreciated...
ok epi
#6398 09/23/03 05:59 PM
Just keep your nose out of the gas tank! and maybe leave a window cracked in your garage.
#6399 09/23/03 07:41 PM
no, no, mrmack,
the gasoline sloshes out while I'm driving...and sets on the top of the gas cap & vicinity...and the vapors make their way around and to my brain (what's left of it, anyway)...which is why I'm trying to preserve the few grey matter cells I have... laugh
ok epi
#6400 09/23/03 08:41 PM
I can only suggest adding an additional layer to the bottom or top side of the cap. Some screen or fabric with tiny openings or a cup with a hole in it added to the bottom side. Or a cover with vent hole on the top of the cap. If on the cover you will need to have something that will clear the bottom of the seat and have some provision to remove and tighten the cap.
#6401 09/23/03 11:28 PM
chip,
thanks, but is this issue unique to my gas cap?..
ok epi
#6402 09/24/03 12:28 AM
OKAY, I didn't quite get your drift. the vent should NOT do that, maybe you can get a good cap or place a piece of gasket material inside the cap so that gas vapor will vent but not the liquid. ....Sorry!
#6403 09/24/03 10:35 AM
maybe I don't have the correct gas cap?..can anyone describe it or post a picture of the real deal?..
ok epi
#6404 09/24/03 08:53 PM
Kepi,
You likely have the correct cap. It is a common problem to have a little gas on top of the cap on a bouncy road with the gas tank 3/4 or more full.
#6405 09/25/03 01:25 AM
chip,
that's it, exactly...and around here, seems the only place there aren't bumpy roads is where there are no roads...
are repop caps available?..maybe I could get one and try some mods to it, maybe add a vent tube?..what do you think?..
ok epi
#6406 09/25/03 07:43 AM
xxx Offline
How long (if at all) could he run a non-vented cap when he is driving so he doesn't get sick? :confused: When he arrives or parks he can replace the non-vented with the vented one. laugh
Don't jump on me if I'm totally out in left field, I really don't know how critical the vent is for short times. ok
croc
