Posts: 184 |
What is a good source for the engine color, dark blue gray? Is there any spray paints available for touch ups?
Seeing the USA in a (1930) Chevrolet
Suggest you contact: The Filling Station: www.fillingstation.com
Posts: 3,542 |
There has been a great deal of discussion on 'Chatter' on the correct 6 engine paint and the FS is about the only place that has the "correct" color ("correct" means backed by some good evidence). :) If you do a "paint color" search of 'Chatter' you will find some very interesting discussions on this topic. :eek: You will also find with your 'search', some discussions on which items in the engine bay are painted black (and which black) and which are painted engine color.
Posts: 184 |
Thanks for the info.  Again Thanx
Posts: 1,281 |
My 32 engine Is painted with the paint that the filling station sells, and the color, paint, And putting It on Is the best. I do not use a spray can for touching up. The paint can be brushed on for touching up different spots and the paint blends In perfect. Good luck
Posts: 3,578 |
There was some talk that the FS paint was pre-thinned and could be sprayed right from the can.I did not find this true and did need to thin it quite a bit but as CHEVY said its a great paint to work with...chef-
Posts: 3,578 |
Yah,JYD I think you had said that sometime back,I tried it with no luck but after thinning I got a great look and maybe a better yeild?What ever the case its good paint and I received my can( unfortunatly it was dented and leaking)the FS sent me another can a.s.a.p.so I ended up with 1 3/4 qts of paint...chef-
Posts: 184 |
Ok, I have removed cleaned up the transmission from a recently acquired 1930 engine. The bell housing is painted. Looks good. The question is now, is the clutch fork painted dark blue grey, black or is it bare metal? I am thinking the fork should be dark blue gray. Everything I have read is that the engine was painted after assembly. :confused: Any assistance on this and information on the engine compartment is greatly appreciated.
