#609 04/02/02 11:11 PM
rs50 Offline OP
I have a radiator shell for a 29 4 door that is damaged. Does anyone know where I can get a reproduction or someone who can reapair the damage
#610 04/02/02 11:20 PM
No one is making a reproduction 1929-30 radiator shell. You actually have two options. If your shell is restorable then you should get it repaired. The other option is to find a better one and then have that one repaired and replated. I had the same problem with the shell on my 1930 Sport Coupe. I went through about 5 shells and then I found one that I could live with...but it too needed lots of repairs. It sent it to Master Plating in San Diego, California and I got a Rolls Royce shell back both in quality in the plating, and craftsmanship in the repair. My shell is now absolutely beautiful! :eek: laugh :) laugh laugh laugh
#611 04/03/02 02:24 PM
rs50, I have a shell that needs work, is cracked at rivets, has small dents but may be better than the one you have. <aeba38@yahoo.com>
If you have old Chevrolets, other old Chevrolets will find out where you live.
#612 04/03/02 09:56 PM
rs50 Offline OP
junkyard dog. Thanks for the info. I may have found someone locally who may be able to repair mine. I will check into the place you mentioned
#613 04/03/02 09:58 PM
rs50 Offline OP
d2d2 I would like to see pics of the shell if you have any. Thanks
#614 04/03/02 10:00 PM
Sure, glad to help out! Master Plating does some fabulous work....but they are kind of spendy too. However, I learned years ago to never take anything of value to my local plating shop. Good luck! :eek: :confused: :eek: laugh laugh
#615 04/03/02 10:07 PM
rs50 Offline OP
junkyard dog. Most plating shops are spendy and I know what you mean about local shops
#616 04/03/02 10:41 PM
rs50, please send me an e-mail address for your photos, I also have a steel shell with no cracks and fewer dents than the plated shell.
