Hi All,
I have a 1925 Chevrolet Touring that needs engine work. It makes a loud tapping noise in one of the cylinders closest to the firewall and these two spark plugs appear to have oil on them. It also has a burnt smell at this end of the block. I am assuming this is a piston problem that will require an engine rebuild. So, here are my questions:
1) Am I better off rebuilding the engine or trying to find another? What should I expect to pay for either of these options?
2) Does anyone know of a reputable mechanic in Northern California who could do this work?
Any ideas on either the diagnosis or the cure would be appreciated.
Thanks,
Joel
