#57716 03/28/06 12:20 AM
Jimmy B Offline OP
G'day, is there a particular order in which to remove the head bolts? is it the reverse of the installation order? Does anyone have a diagram?
Cheers
Jimmy
chevy
#57717 03/28/06 03:40 AM
Start with the ends and work to the middle. Also stagger from side to side.
Agrin
#57718 03/28/06 03:46 AM
Ray are correct and here is the diagram
[Linked Image from img362.imageshack.us]
Arvid :)
#57719 03/28/06 09:23 PM
Jimmy B Offline OP
Thank you Ray & Arvid, that is exactly what I needed.
Cheers
Jimmy
chevy
#57720 03/29/06 02:20 AM
Funny, I was always taught that you start from the middle and work outwards. This is the opposite. This is the loosening sequence, or am I wrong?
Dave :confused:
#57721 03/29/06 02:30 AM
I was always taught that in tightening you started from the middle and worked your way out. In removing you started from the outside and worked your way in.
Bill
#57722 03/29/06 03:25 AM
I have follow the diagram om several 4 cyl engines,and have not have any truble with the head / gasket. Remove the bolts, I have reverse the installation order.
On 6 cyl Chevrolet Repair manual they say from the middle and out. I have also used this diagram on several 6 cyl engines, and no truble.
I agreed . From the middle and out sounds more correct.
[Linked Image from img229.imageshack.us]
So ,I don't know. I think from the middle and out also will work on a 4 cyl engines. Your choice :)
Regards Arvid wink
#57723 04/03/06 09:40 PM
Jimmy B Offline OP
On Sunday I went to a Vintage car auction, along with the severe sunburn I bought the remains of '26 Chev for $175
[Linked Image from img.photobucket.com]
& a rebuilt '29 frontend for $60
http://www.members.optusnet.com.au/scottnotley/Upcomingfrset.htm
Lot 35 is what I bought it was listed as a "TEENS CHEVROLET TOURER WITH THREE PORT HEAD"
http://www.members.optusnet.com.au/scottnotley/PhotosNextSaleMurphy.htm
So I am extremely happy
Cheers
Jimmy
chevy
#57724 04/04/06 07:35 AM
He Jim,
Good buy, looks like it needs mayor work, but you'll get her back together. I'm just glad I wasn't there; I might have bought them all. I have this weakness for rust, wooden wheels and stove bolts.
Why is it that furniture only gets more expensive in time and cars and trucks get cheaper? They put a bigger mark on people than any Louise VI chair I have ever seen. (Pardon My French, Dutch guy typing here)
This weekend I was at a farm auction and found a complete '52 Chevrolet, I set my max at $100 Canadian, just to save the poor car. It went for $200 Canadian, only one other bidder, but passing my max with 100 % I had to let go. For a view of the car, look here . The wood under the engine is a stupid mishap, in the seventies the owner’s son wanted to lower the whole car and heated the springs, while it was still standing on its wheels. auto Oops! Then the grader guy wouldn’t let him drive it anymore over the gravel roads around here, job protection.
Old running trucks go for $200-$700, not running trucks for parts $2- $150, rural life in Canada is great laugh now I just need a bit bigger wallet.
Great buy; please keep us posted about any progress
Regards
Richard
How sweet is the roar of a Chevy four (Thanks Chipper)
#57725 04/12/06 02:46 AM
The 3 port head is off an FA-FB series engine
Chris
#57726 04/13/06 12:18 AM
Jimmy B Offline OP
Originally posted by Truck'26:
He Jim,
G'day Riichard, that's good! when I modify it for hillclimbs I won't get strips torn off me for wrecking an 100% original wink
That thing would get at least $1500 around here, she looks pretty solid.
That is similar prices to the auction I was at.
Will do!
Cheers
Jimmy
chevy
#57727 04/13/06 12:22 AM
Jimmy B Offline OP
Chris
G'day Chris, did they have a Clover leaf cast in the middle between the valves?
Cheers
Jimmy
chevy
#57728 04/13/06 03:03 AM
Yes - the clover leaf with the letters SPC inside is the casting mark of General Motors owned Saginaw Products Commpany. The machine work was done at the Saginaw Motor Plant. Chevrolet only used this GM's Saginaw 3 exhaust port heads on its 1922 FB and T models with other GM divisions using this 3 port head earlier from 1920. Did you find the cast date?
KenK
#57729 04/13/06 09:46 PM
Jimmy B Offline OP
Thanks for that info Ken :)
It has 5-9-21 cast into it. So 9th May 1921 (I still wonder why the US puts the month first :confused: )
Cheers
Jimmy
chevy
#57730 04/15/06 07:23 PM
In Australia we say (as you quoted) 9th May 1921
In the US they say May 9th 1921, thats why the month is stated 1st
Chris
