#57580 03/13/06 11:09 AM
Betsy Offline OP
I am just curious as to how much it typically caosts to redo an engine. Mine is running fine, I am just thinking of the future.
#57581 03/13/06 11:10 AM
Betsy Offline OP
Sorry, Betsy is a 28 National 4 door sedan.
#57582 03/13/06 11:49 AM
If you do it yourself it might only cost a few hundred to replace worn parts. If you hire it done then $ 3-5 K.
#57583 03/13/06 01:08 PM
That answers at least one question for me. :eek:
Bill
#57584 03/17/06 01:24 PM
I was told to expect approximately $1000 per cylinder do a complete rebuild of a babbit bearing engine.
Chris
#57585 03/17/06 01:55 PM
If your engine is running fine, I advise you to leave it alone. And, there's a lot of difference between a complete rebuild and an overhaul.. If you're interested in the general condition of your engine, drop the pan and check the connecting rod babbit and adjustment. If that looks good, probably the the engine is OK. Clean and check the goop in the pan, if any, and that will tell you more..After all, you're not using the car as a daily driver like some of us did when we were young...Back then, the first thing we did with a $50 Chev was to drop the pan and find out if we could depend on it to get to work.
#57586 03/17/06 02:42 PM
Just had a 1935 6 cylinder engine done; a complete overhaul new everything, including pistons, pins, rods, mains, valves, lifters, timing gears, hardened valve seats and oil-lite guides, new gaskets, new clutch disc, throwout bearing, pilot bearing and flywheel refaced: for a total of $1950.00 including deck refaced on block & head, block rebored, and align-bored mains. Work done by Docker Motor rebuilding Charlotte, Michigan.
#57587 03/18/06 09:59 AM
That sounds like a great price. I'd jump at it if I found it nearby.
How long did it take them?
Jim Barnhart
Temple City, California
Link to Jim's Chevy
1929 Sedan
1969 Corvette Coupe
#57588 03/18/06 12:08 PM
Just in case you need the address is as follows; Dowker Engines, 502 Island Hwy., Charlotte, MI 48813 Phone 517-543-0249.
#57589 03/18/06 12:33 PM
Jim- Is that who did WaltD 's engine?
#57590 03/18/06 01:55 PM
Walt had one engine rebuilt in Plymouth, Michigan; I don't know if he had one done by Dowker but he did give me their address as a posible source. Jim
#57591 03/19/06 04:25 PM
Jim,
I had three six cylinder engines done over the years. The last one 1/20/05 for the 53. I have a 3 yr warranty on the long block assembly. the Builder is Chuck's Engine Exchange, Inc. and he has been in business for years. His phone 734-354-0670, Plymouth, MI. I know he does guite a few older engines along with late stuff. Usually has the engine done within a month. Total cost $2,000
The rods were converted to inserts.
Walt D
1934 Mstr 4 dr/sidemnts
1937 1/2 ton P/U
1953 Bel Air HT
1946 Aeronca 7-AC Champ
