I have a 1935 Chevrolet standard. The stock engine size is 206. I need to locate vendor or catalog source for valve cover gasket and push rod gasket. I also am having some difficulty finding correct engine paint and source to purchase the paint. Last area of questions (at least for this time) what is correct oil weight to use in tranmission and rear end? Thanks to any help and answers.
Rob Butterfield
chevyrob35,
welcome...click on it to go to the vendor index where you will find the filling station (& other great suppliers) for parts & engine paint...
your questions have been discussed previously, some on several occasions...to review those threads, use the search function for all or specific forums...this will help you get much of the you information you seek...
and, if you don't see what you need, come back and post again...
good luck,
ok epi
