#57158 01/03/06 11:04 AM
dads 28 Offline OP
Hi Gang
Has anyone had replaced the rivets on the axle stops that are inside(under) the saddles. Mine are loose and leaking,I was planning to drill them out and plug weld the holes and the stops to the tube. cool Any thoughts?
dads28
#57159 01/04/06 01:56 AM
If I remember correctly I plug welded my axle stops.
(.)(.) ( Y ) (.)(.) ( Y ) (.)(.) ( Y ) ( Y ) ( Y )
#57160 01/06/06 05:21 PM
dads 28 Offline OP
Thanks Kip. Maybe the Easter Bunny will bring a welder and I'll be all set. Agrin
dads28
