#57127 01/15/06 04:12 AM
ozmax Offline OP
Hi all I am hoping you can help me identify this part that cam with my 28 chev. it is a bracket whats it for? and where does it go? thanks Ozmax
ps how do I add the photo?
#57128 01/15/06 04:53 AM
email the picture to me and I will post it for you.
bigbob@rdgsons.com
#57129 01/16/06 03:27 AM
Posted for ozmax
[Linked Image from rdgsons.com]
#57130 01/16/06 04:08 AM
This is too easy. That is the bracket and strap that holds the muffler.
Agrin
#57131 01/16/06 12:47 PM
It is attached to the frame on the passenger side opposite to the battery box which is on the drivers side.
#57132 01/16/06 05:11 PM
ozmax Offline OP
Thanks for your help. Being right hand drive it would be on the drivers side for me, after having a look it must be bolted on with one of the bolts that hold the running board brackets to the frame. there are two holes on the muffler bracket the one that you can't see in the photo is to bolt to the frame whats the other one for? or is it bolted on with one bolt? Thanks for you help as you can see I am new to chevs I am restoring a basket case, the car was pulled apart by a number of previous owners and I am slowly working out what goes where. thanks again everyone!
#57133 01/19/06 06:00 PM
Ozmax
Give me a ring on 02-46257547, I've been into 28 Chevs for 35 years and should be able to help you with your restoration, I'm in Campbelltown NSW
Chris
