#57070 12/22/05 05:16 PM
Jimmy B Offline OP
G'day, does anyone have any specs on the '25 Chev Bottom end, main & rod journals? also is there anyone making modern insert bearings for this model?
Cheers
Jimmy
chevy
Hi Jimmy B,
Front: 1 3/8 X 2 5/16, Center, 1 11/16 X 1 11/16, Rear: 1 3/4 X 3
Center bearing is thrust bearing.
Rods: 1 1/2 X 1 7/8
I don't know of any after market solution for the crank bearings. The shells may be removed and re pored. Then it needs to be alined bored. If equipped, I recommend removing the bearings and pore the mains directly in the block. It still needs to be aline bored.
If this is a rebuild, you may consider replacing the pistons with modern pistons, and modifying the rods. Full details are available under "School is in Session" on this forum.
Agrin
Jimmy B Offline OP
Thanks Ray!
Is the first measurement the journal diameter?
Cheers
Jimmy
chevy
Yes, I should have done a better job of labeling.
Agrin
