#56727 10/06/05 11:21 AM
Just bought 4 used tires to go on my 21 Baby Grand. 32 x 4 1/2 They seem to fit loose with about 3/8 play all the way around. Every other demountable tire I have had to put on, I've had to wrestle with to get on. These "fell" on. Is there such a thing as a 22" rim? Is that what I have? I'm a little baffled, wanting to get a set of "shoes" on my car. The tires are made in England, but do have the sizing in inches. I inflated the tire and it stays on, just doesn't look right....
#56728 10/06/05 12:45 PM
Looks like you might have the wrong size tires or wheels or both. According to my March 15th, 1921 FB parts book [and also my Sept. 1, 1920 FB pb) two wheels were available. U.S. wheels (ft pt # 43724, rear pt # 43667) and rims (pt # 44763] were 32"x 3 1/2" both front and rear. An (Export only) 815 x 105 MM wheel and rim was also available for right drive models. My conversion makes them a nominal 32" X 4.1". My Sept 1. 1924 FB parts book shows both front and rear wheels and rims were also 32" x 3 1/2" with rims (44763)and black rear wheels (43667) the same part numbers. The brown rear wheels (pt # 24426) and front wheels (pt # 23759, pt # 23760) had different part numbers. From that I would conclude that tire and wheel size was not changed until the Superior model introduction in late 1922.
My ca 1919-21 (show single exhaust port head) FB & 490 sales booklets all show 33" x 4" tires for the FB. "Non-skid on rear. Plain tread on front".
#56729 10/07/05 07:56 AM
Chipper, now I'm thoroughly confused! Your #s come out to a 25" rim, but my rim is a tad small at 23". I just read in small type on my tires,"for B.S. rim". The word BUTTRESS is on the tires. This is BS!!! LOL!!! If I were to put 25" tires on my car, I'ld have a couple inch gap around my rims. My wheels appear to be correct to the car, but who knows? Maybe someone did a swap years ago....
#56730 10/07/05 10:14 AM
My '19 FB is 120 miles away so I can not measure the rims or check the tire size to be sure. My Chevy literature indicates that the '23-26 models used 23" wheels so the wheels might have been changed by a past owner.
#56731 10/08/05 08:02 PM
My "19 FB Baby Grand" has 33 x 4 's. There is an article in the August issue of "Hemmings Classic Car" about a 1920 FB-50 Touring that includes a spec sheet calling for 33 x 4 tires on 25 x 4 wheels, both front and rear.
