Posts: 56 |
Hello iam Stephan from Switzerland
i have a chevrolet 130 4 door sedan and that i can drive in switzerland i need the turn signal. i see some kits on the net but maby somebody know a good kit for my car:-)? thanks Stephan
Stephan.Messmer@unibas.ch
Stephan,There are turn signal switch kits available from www.fillingstation.com.They are just the switch and flasher.For lights you can buy the lights such as used on trucks and trailers , the type that would clamp to your bumper braces.These are much brighter than your tail lights but may not look as good.It depends if you want safty or make it look original.It would be necessary to convert the lights to 6 volt bulbs-no big problem.
Posts: 3,542 |
Do you have cowl lights in the front now? If so, they can be used for the turn signals in the front.
Do you have 2 tail lights? If no, The Filling Station also sells all of the right hand tail light parts, with 2 taillights you can use them for the rear turn signals.
Use the "search" link on this site and you will find discussions on how to install the lights.
Good Luck.
