Posts: 10 |
I am looking for the throttle adjust that hooks to the carburetor to advance the throttle to a faster idle on a 1928 the rod from the steering gear is still there but the piece on the end of the carburetor is missing to hook it into any ideas where one can be found or what it is called I looked in the filling station catalog no luck so far
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
Kordon_capone Try Gary Wallace 600 Susan Rd. St. Louis Missouri 63129
Chev4cyl@charter.net OR (314) 293-1991
He lists them in his catalog.
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Kordon, I probably have it, how long is it? E-mail me bwbugay@aol.com
The throttle lever and shaft (has throttle plate screwed to the shaft) has two ends with each with holes that the throttle rod and foot pedal linkage rod fit into. Is it the arm on the throttle shaft that is missing one of the ends? Or is it something else? I should have or can make what you need.
Posts: 10 |
it is the end that the throttle rod goes to that is missing off the end of the rod on the carb I am guessing it should look almost the same as the one the accelorator is hooked to
