Maxie Offline OP
I have two rear fenders to attach and I see the two rear brackets that attach the back of the fenders to the frame. I think there is an angle iron type of bracket that attaches the front of the fenders to the running boards. Is there any other attachment area that holds the fenders to the truck? Thanks, Maxie
The felt o-rings for the top of the lifter rods came in today..... they will be on by morning! It was a good day at the Closson's.
"Preserving the old fashion way... for the fun of it."
Hi Maxie
On the top of my rear fenders at the inside there is a small right angle bracket which attaches via the bolt hole on the inside to the timber cross brace of the tray. Should have 3 points of attachment frontof fender to running board a the top on side bracket and bolt and at the rear on the side two little holes with a bracket that bolts to the rear side of the frame near the rear spring hanger. Hope this helps
