#55635 03/27/05 08:38 PM
Hello All. I have an old car that my Father and I always thought was a Mercer Raceabout, but after looking past the radiator emblem everything says Chevrolet. For all aesthetic reasons it looks like a Mercer, but has a Chevrolet 4 cylinder (G137?) engine and 3 speed box, 10 bolt banjo style diff, and rear drum external shoe brakes, 21 inch wooden wheels etc. All driveline items mate eachother correctly, and all mountings look original and untouched. I have a list full of part and casting numbers from most driveline components, but have been unable to find any chassis markings. I have a fist full of digital photographs, and was wondering if anyone could shed some light on what this car may be!
#55636 03/27/05 10:07 PM
The engine clue equates to Jun 13 1927. Don't know for sure, but assume that number came from the engine. The head will also be dated in the same format. Suggest you post that date also. If you will send me one or two pictures I will make a stab at what you have.
Agrin
#55637 03/28/05 02:01 AM
Hi Sphoenix
Great to see that there is some more guys from Australia getting onto this site. If you can email me some details or even some photos I can help you establish just what you have.
It would be great to find out a bit more about the history of the car and some of the modifications that have been done and what era they were carried out.
I am located just out of Sydney but could also put you in touch with others in South Australia if you let me know where in SA you live.
Drop me a line I would be glad to help.
TWIN4
#55638 03/28/05 06:21 PM
Hello again. I'll list off the numbers that I have found, and send you both some photos. Can photos be posted on here, I can't see a link!
Engine Number - R3582755
Engine Block LH side - G137
Engine Block RH side - 346709
Cylinder head - 346886 (also has 3 leaf clover with PSC inscribed)
Bellhousing - 346871 ( with Chevrolet logo)
Gearbox - 590279 B LH side and F3 on the RH side
Gearbox coupling - 590182
Shifter hat - 590281
Diff - 344021
Carburettors - 2 Carter carbs # RX-0
Water pump - 146707-15
Generator - Delco Remy 943B 668192
Spark plugs - AC 28S
That's about it folks. Hope that enlightens someone!
Cheers
#55639 03/28/05 06:25 PM
#55640 03/28/05 06:26 PM
Ha Ha. It works!
#55641 03/28/05 06:28 PM
#55642 03/28/05 09:22 PM
Well, first off, it appears to be an assembled Racer, chassis looks like 1927 Chevrolet, engine is base 1927 Chevrolet and highly modified. Radiator shell probably came from some other vehicle and the remainder of the body appears to be hand made.
Headlights may be F O R D.
Too bad they put the steering wheel on the WRONG side.
Agrin
#55643 03/28/05 09:25 PM
Great looking speedster. Does the Cylinder head have one or two exhaust ports?
#55644 03/29/05 12:12 AM
The head has 1 single exhaust port exiting the centre of the head!
#55645 03/29/05 12:44 AM
Huuum. Starter also on the wrong side?
#55646 03/29/05 12:45 AM
Why would someone use a 1927 engine with all the advantages that a 1928 can offer? Especially for a racer.
No starter used to reduce weight. Push start.
Appears to be a pressure fuel system with a hand pump located somewhere. No indication of a source of vacuum from the constructed dual intake manifold.
Agrin
#55647 03/31/05 08:06 AM
Here's a question? Why did they use a balance tube between the carbs when both carbs enter into a common manifold?
Tim.
He who ignores the rudder answers to the rocks. When Fear advances, Logic retreats. I could go on...
#55648 03/31/05 08:10 AM
Great car, by the way! I am tempted to build something similar out of my pile of left over bits.
Tim.
