#55491 03/13/05 08:43 PM
Bob23 Offline OP
The ignition switch on my 23 Roadster was by passed several owners past so I assume the switch has failed.They added a series of toggle switches and made a mess of the wiring so my goal is to undo this mess and start over. I want to remove the switch without damaging it so that I can make an attempt at repair and if that fails find a replacement. I don't have a key but the switch moves back and forth. After removing the two screws that holds the switch to the dash what should be the next step? Does the switch have to be in a certain position to remove? Any thoughts on bench repairs? :confused: :confused: :confused:
Thanks,
Bob
#55492 03/13/05 09:20 PM
The key (bad choice of words) to your switch is the small cylinder in the center of the lever where the key enters. That cylinder is pot metal and usually swollen and cracked. The two screws is all that holds the switch in the dash. There will be several wires to remove from the backside.
Careful on opening up the switch as several small pieces are poised to make a get-a-way.
Agrin
#55493 03/13/05 10:02 PM
Gary Wallace now sells a reproduction die cast cylinder for those early ignition switches.
#55494 03/13/05 11:19 PM
Bob23 Offline OP
After removing the two screws the switch will not move. Does the cylinder and handle pull out of the electrical part of the switch? If the cylinder has swelled could this be what's holding the switch? Haven't used much force. :confused: idea :confused:
#55495 03/14/05 05:33 PM
I have carefully bent the tabs on the back of the switch that hold the back of the switch on. As AntiqueMechanic said, do this carefully to make sure that you see how it comes apart. If I remember correctly, there are only a few parts inside.
The switch is very basic, as when you rotate the two parts, they simply contact the different posts where the wires are attached.
There were two different keys used on all 1923's. If nessicary, I can trace one of my keys and you can cut it out of 20 gauge sheet steel if nessicary. That's about all my keys are. Good Luck and let us know when you get it fixed.
Chris
#55496 03/14/05 10:09 PM
Bob23 Offline OP
I didn't do a very good job of posting my follow up question. I'm still trying to remove the switch from the dash. Here's what I have. In the front of the dash I have the cyclinder,lever, and bezel along with the two screws. In the back I have the main electrical part of the switch. After I remove the screws the switch will not come loose. I haven't done any prying or used much force. Any suggestions on the next step. If I should use some force where should it be applied?
Thanks,
Bob togo togo togo
#55497 03/15/05 08:45 PM
Bob23 Offline OP
Thanks Ray and Chris for your help. After reviewing your suggestions I decided I needed to apply a little tender loving force to get the switch out. It was in the dash so tight with 82 years of rust and paint that I didn't realize it just pushed through the dash. togo Well it's out and like Ray said it's only held in my the two screws. Now we'll see if it can be saved.
Thanks,
Bob :) :) :)
#55498 03/15/05 09:03 PM
If you need help with the switch I would be glad to do so.
Agrin
