No, this must be a fairly tight press fit. I would recommend you go with a fiber gear on the camshaft and the metal gear on the crank. The 1927 engine was just the opposite.
The big objection to the metal gear is the noise.
The loose gear can be corrected by knurling the cam shaft and the use of thread lock compound.
The cam gear is unique on the 1928 engine. The width must be the same as the crank gear.
Check timing mark on any gear you use as many were incorrectly marked.
COMMENT; It is too bad that most of my pictures were destroyed on the "School is in Session" by closing a web site without warning. Problems like this were covered in detail on that thread.
