Maxie Offline OP
How would could I tell if I have a
1. Late 1927 Chevy Capitol 1/2 Ton Truck
or a
2. Early 1928 Chevy Capitol 1/2 Ton Truck ?
Is ther anything on the cowl tag that definately tells this?
"Preserving the old fashion way... for the fun of it."
Post all the information from the cowl tag, engine pad number, and the date code from the block and the head and we will break it out for you.
Also include the information from the title.
Agrin
Maxie Offline OP
Cowl Tag Information-
Model: Capitol
21L0 10328
CHASIS WT 2030
MAX PASSANGER PLUS LOAD 6150
Engine Stampings-
T454288
848532
Bowtie17
Maxie Offline OP
Model: Capitol
21L0 10328
CHASIS WT 2030
Engine Stampings-
T454288
848532
Bowtie 17
E2 48
Maxie Offline OP
Head # 438540
Capitol=1927
21=Janesville plant
LM= 1 ton truck
10328= assembled late July
Agrin
Maxie Offline OP
1.Ray, For the uneducatied... You mean Capitol was built only in 1927?
2. What state is the Janesville plant in?
3. How is 10328=July
4. Why is LM=1 Ton truck (I though 6 lugs was a 1/2 ton and 8 lugs was a ton?? Thanks Maxie
Janesville is in Wisconsin. laugh laugh laugh
Ray must have gotten something on his glasses. 21 LO is a 1928 assembled in the Janesville, WI plant. It is a 1 ton "Capital" as both '27 (LM) and '28 (LO) used that name. They only have rear brakes. The late '28 LP was also called "Capital". They have 4 wheel brakes. Not sure why they are not National models.
Chipper is correct. My finger got on the wrong line. Soooooooooooooo,
Capitol = 1927 (This was information provided by you from the data tag)
National = 1928
These designations were made by Chevrolet.
Janesville, WI
10238 = Late June for the LO truck and was almost the last LO assembled. July was the start of production for the LP at the Janesville plant. (Information based on figures provided by Chevrolet. The first truck assembled in June was 9845 and the last truck was 10474 in the LO series).
LO and LP were both 1 ton trucks as designated by the LO and LP.
Agrin .
Both the 1927-28 Chev 1 ton Trucks were called Capitol like Chip related in the USA because the 27 front sheet metal and radiator design was carried over from 27 to 28. This series LO is a 1928 Capitol LO series 1 ton truck built in July oof 1928. The 1928 LP Capitol 1 ton went into production in August 1928 with 4 speed gear boxes as standard and 4 wheel brakes. National was only used in the USA for the 1/2 ton truck model with the series being AB. kenk
Any validity to the 6 Lug/8 Lug theory?
Tim.
He who ignores the rudder answers to the rocks. When Fear advances, Logic retreats. I could go on...
I don't think Chevy used any 8 lug wheels until after WWII on 3/4 and 1 Ton models. 37-40 3/4 and 1 Ton used 6 hole wheels. 1-1/2 Tons used 10 hole wheels from 1934 on (maybe earlier).
1.Ken and I would be very interested to know more of the 1927 and 1928 finish car and utility express serial numbers for each plant! We have calculated the last 1928 LP series from the ledgers. I suspect that the digit is after the '45'..by the way the 'T' is a left hand drive TRUCK engine.
2. There seems to be digit missing from the quotes engine number. The interest is in the exact cut-off when LO engines switched to LP engines ready for the July 1 1928 change-over. So far we suspect that LP castings date from around June 21.
3. Although it is spelled 'CAPITOL', in Canada, it was also spelled 'CAPITAL'. Likewise, it was Series L.O. and L.P. [note full stops/periods].
Maxie Offline OP
Hello Oracle, I rechecked the engine numbner and found it indeed to be missing a 10.
Should have been:
T4510288
348532
bowtir 17
E248
Thanks, Maxie.
