Posts: 9 |
These are the parts I need for my 28 Chev 4 Dr. Main Sill Cover Panel - left and right side Windshield Wiper Motor Rear End.
Can any one help. Ken Feren.
Let Me Know Prices.
Ken Feren
Hi Chubbs, The first item can most likely be obtained from Gary Wallace chev4cyl@charter.net. Wiper motor. That item will be a bit tough to find. Put an ad in the parts wanted area below and watch ebay. Rear end? Not sure what you have in mind, the carrier and axles or a ring and pinion. If you want the entire unit it will be best to look local as the size of the item makes shipping impractical. If just the gears, they are readily available.
Posts: 9 |
Look s I need the rink & pinion and gears.
Ken Feren
Gary Wallace has the ring and pinion.
