Anyone have any idea what these are, I received 4 of them with my car (or should I say what used to be a car, is now a garage full of parts, and hopefully will be a car again one day...)
Looks like they would go around the radiator, but radiator already has a shroud that's different than this. Any ideas?
[Linked Image from home.rochester.rr.com]
That is just slightly less than 1/2 of the shroud from a 1928 Chevrolet. Looks like the bottom 1/2.
Agrin
Originally, that is what I thought. Problem is, they are all the exact same, they have not been cut or anything (in original shape). If you lay them flat they are only like 2" tall (deep)
where the ones on my radiator for the 28 are like 4 or 5 inches deep.
"That is just slightly less than 1/2 of the shroud from a 1928 Chevrolet. Looks like the bottom 1/2."
Just went out and took a closer look at one of my 1928s and you are absolutely correct. That one is not deep enough to be for the 1928. I now suspect it may be from a "modern" car.
Agrin
