Posts: 87 |
My 27 steers very hard at low speed. I removed the axel for painting several years ago. I also had the steering box overhauled at the same time. Could I have reversed the axel? Is there castor built into the axle?
Dale Duffield Tulalip, WA. 1927 Sports Cabriolet (since 1954)
The best guess is that the rebuilt steering box is just tight. You may be able to help things by adding some gear oil to the steering box. This may leak out shortly, but should improve the operation. Removing and replacing the front axle would most likely affect the steering while underway. Check the toe in (0 to 1/8). The front axle can be (tweaked) a bit by shimming either the front or back. Would not recommend this if you are not completely versed on caster/camber. Low tires will also affect steering during slow speeds.
Also check to make sure the steering ball ends are round. When they wear they get oblong which makes steering hard. You can purchase new balls and replace them. If you need to replace contact me and I can help with suggestions.
Posts: 239 |
Hi Dale Check Snyders on-line catalog. They have both the weld on type or the threaded type. I used the welded on my 28. Click on - www.snydersantiqueauto.com/modelaparts/steering then search - tie rod balls - or A-3311 or A-3311-W Herb
