Posts: 4 |
can you give me any info on the '27 AA Capitol I have? these are the #'s I found 3665687 and 346709. The body has car No. 1AA87066. Thanks,
pedalpusher
You have a late '27 Series AA. It has the later engine, carburetor, distributor. Engine serial number 3665687 indicates it was assembled about 2 1/2 months from the end of production (~September). The 346709 is the block casting number for 1927.
The serial number 1 AA87066 indicates assembled in the Flint Michigan plant and was the 86066th built in that plant.
Posts: 845 |
Your vehicle was assembled during the month of August 1927 at the Flint Assembly plant as Chip indicated.
The first AA series vehicle assembled in August 1927 at Flint had serial number 1AA 81764. The first AA assembled in September 1927 at Flint carried serial number 1AA 89962. With 8198 AA units assembled during August and yours being number 5302 out of the figure, a fair estimate would be sometime during the third week of August, 1927.
