Posts: 194 |
OK...I'm in fender purgatory again. I bought these on eBay hoping they'd fit my '24 touring. They won't. The mounting holes are in slightly different positions and the triangular valances seem shaped wrong. Anyway, here are some pictures. Maybe one of you will recognize them. ![[Linked Image from home.att.net]](http://home.att.net/~tomchaney/fen_rear.JPG) Note the valances curve inward from the fender about 4" at the bottom. ![[Linked Image from home.att.net]](http://home.att.net/~tomchaney/fen_side.JPG) Mine should have a mounting hole at the white arrow. ![[Linked Image from home.att.net]](http://home.att.net/~tomchaney/fen_frt.JPG) Here's the front. Thanks for any help!
1924 Superior "F" Touring Car
Posts: 26 |
Tom From memory, they look a lot like my 26 coach fenders.(I need better) I have a pair of four door fenders that also fit the touring "26" will have to check to see if they are the same for 24. I am at work and all my info at home.Go figure! Will check tonight. If you may want to trade, give me a jingle. bvg@bmi.net Boyd
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
look like 1925-6 fender to me.
Posts: 26 |
From memory, I was wrong. The 28 parts book calls out different fenders for B,F and 25-26. For the 24 the fender would fit touring, sedan and touring chasis.(341002 & 341003) The 25-26 also fits the touring, sedan, touring chasis and coupe 2, but a different fender than the 24(344471 & 344472). Tom's picture looks real close to the 25-26 touring, sedan, coupe. the only visual difference that I could see was that my 26 fenders have two holes in the apron. I think that it may be time to pull out the old tape measures. Gaby
Posts: 10 |
Hi! Just looking at the pictures I think you have some 1927 fenders. They differ from the 28 in the way they mount to the runningboards. -Couper-
Couper
Posts: 242 Likes: 1
Posts: 242 Likes: 1 |
Hi guys these are not 27 they do have the same mounting brackets for the timber running boards but look to be 26 touring (27 does not have the raised section through the crown of the fender)
Jim
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
They look the same as the fenders on my '26 Superior "K" sedan.
Posts: 1 |
If my memory is correct, those fenders fit a 1958 26" Schwinn Female edition.
You got to add some humor here & there!
EIGN SIGN
Posts: 11,162 |
