#54019 12/02/03 03:23 PM
Saw a 28' truck front fender for sale in the generator and would buy it if it would fit (be the same as) my 27' fender. Does anyone know if they are the same???
Also, is there a way to remove the bowtie emblem from the front of my radiator shell w/o destroying it--so that I can clean up and paint behind it??
scott walker
#54020 12/02/03 03:46 PM
The fenders are the same.
To remove the emblem from the steel shell, and to prevent damage, requires you to take the radiator out of the shell and work from behind. Assuming it is still an original emblem, it is just pressed into the shell from the front. If it has been replaced it may be secured by a bolt.
Agrin
#54021 12/03/03 02:03 AM
Yes 1 Ton,
And if it's soldered to a flush head fastener, like the last two Asian Repros that I bought, It will just fall off if you wait awhile. Also if the background plate is original with the green patina still on don't clean it. Like original copper pennies it's worth more that way.
Herb
#54022 12/03/03 09:37 AM
The emblem appears to be original--unfortunatly I already cleaned it. Is there a way to push it back out from the rear without damaging it??
scott walker
#54023 12/03/03 12:53 PM
Yes, just work carefully.
Agrin
#54024 12/11/03 08:35 PM
hows this for fate my friend bill found the radiator emblem that is the 26 on the bank of the ohio river years before the truck was ever bought wich of course was minus the emblem we he bought
alan
