Posts: 11,162 |
This Coach is all Original, with a hot water heater! Ebay 28 Coach ![[Linked Image from i3.ebayimg.com]](http://i3.ebayimg.com/02/i/01/0f/2e/fc_1.JPG)
Posts: 29 |
LOOKS LIKE THE WRONG COIL ALSO!
Posts: 115 |
"Listen to the Roar of a Chevrolet Four!"
Posts: 56 |
WISH MINE HAD THAT OPTION THIS TIME OF YEAR
1928 NATONAL AB COUPE
Posts: 11,162 |
Huffneff, that looks like the right way to install a hot water heater, first one I have actually seen on a 28, I am sure there were many that were modified like this one during the late 30s and 40s. I wonder if a restrictor plate is needed above the inlet to the heater hose connection on the upper radiator hose to the heater?
Posts: 56 |
I WOULD THINK SOMETHING WOULD HAVE TO BE INSTALLED TO CAUSE THE WATER TO GO WHERE YOU WANT IT INSTEAD OF THROUGH THE RADIATOR. ALSO I WOULD THINK ONE WOULD NEED A VALVE TO SHUT THAT CRITTER OFF IN JULY
Posts: 11,162 |
my 53 heater just comes off the waterpumpI think one could drill the theomostat housing and tap it for a 1/2 or 3/4 pipe and put a shutoff valve on before the hose nipple. I wonder why Chevrolet didn't make a good looking heater like this one: ![[Linked Image from i4.ebayimg.com]](http://i4.ebayimg.com/02/i/01/03/c7/5e_0.JPG)
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
There is a 28 for sale on Aus ebay too. Last I saw was about $au10000 after restoration???. I dont remember item #
Posts: 239 |
This is likewise the first hot water set up I've seen on a four but as I recall on late 30's and 40's ( mostly aftermarket ) I think the line to the heater was upstream of the thermostat so the natural flow was first through the heater core. Herb
Posts: 12 |
Why would anyone want a hot water heater? My hot water has always been hot enough.
Don V
Posts: 20 |
