#53627 08/28/03 04:20 PM
Casper Offline OP
I will be puttng a small trunk on the rear rack of my 1928 tourer which will partly obscure the rear number plate. Does anyone have a photo of an alternative mounting place for the numberplate/brake light?
Casper
#53628 08/28/03 09:19 PM
On the rear of the trunk is where mine ended up.......
#53629 08/28/03 09:25 PM
Where are you fellows getting all the trunks to put on the back of your tourings? Any pictures available?
Agrin
#53630 08/28/03 09:56 PM
Casper,
I have sent you an email re photos of my offset tailight/numberplate bracket. Will supply photos to anyone who can post 'em here for me.
Tim.
He who ignores the rudder answers to the rocks. When Fear advances, Logic retreats. I could go on...
#53631 08/28/03 10:55 PM
Yeah, where ARE you all getting these trunks?
Does anyone like Oldie or some other 4 cylinder Guru have a drawing of an acceptable trunk for a 28?
Tim give me a try, I think I can post them.
mrmackc@msn.com
#53632 08/29/03 02:24 AM
Casper Offline OP
I think most people use old travelling trunks with the timber rails or even the all-metal trunks. I have seen "real" vintage car trunks on Ebay and at the local antique shop (for a price!). The latter always seem to require work to restore and don't look all that special when finished so folks I guess choose to restore a "prettier" timber trunk or whatever.
I am restoring a timber trunk with a metal outer shell and the original paper lining (although I might upholster the inside). The finished colour will match the car.
Casper
#53633 08/29/03 01:26 PM
If you click on -
www.antelecom.net/herb/herbc.htm
I have a picture of my 28 with matching left and right tail light and license plate bracket. With wire wheels installed the center mounting will not work and this method allows turn signals and emergency flashers. I copied the bracket from Tom Meleo's 28 Roadster which also has wire wheels, but it may have originally been on a 28 pickup truck. E-mail me and I can make a sketch or photo of the bracket.
Herb
#53634 08/29/03 02:22 PM
Nice pictures of the '28 Roadster but it looks like one of those modified cars we read about.
Joined VCCA June 1, 1961
#53635 08/29/03 03:36 PM
Casper Offline OP
Yes, very nice Roadster.
Tim gave me some close ups which woould be similar to what you have and I think I wil adapt the basic idea from these.
Thanks for your help here
Casper
#53636 08/29/03 07:47 PM
I can't see them in detail. Looks like they mount like the tail light bracket used on 1930 passenger cars with wire wheels. If so it could be an original Chevrolet part. Not the exact year but at least Chevrolet.
#53637 08/29/03 10:51 PM
Oh My God! the carburator is on upey-sidey down!
#53638 08/30/03 09:47 AM
#53639 08/30/03 03:24 PM
You are correct Jimo.
Also judges won't give extra credit for the W-1 Carb, Model A pistons and rods ( 189 cu in ), Weber 3/4 cam, Wire wheels, 32 Headlights, Ignition key starter, Double mirror, Electric fuel pump, etc. The previous owner made most of these mods years before there was a VCCA so I consider them grandfathered in. I plan to keep it this way and may even add juice brakes as stops from 70 mph are somewhat dramatic.
Herb
#53640 08/30/03 04:09 PM
Herb I guess you have an original "HotRod", it should be a H@@T to drive!
I suppose you will go all the way and install 4 wheel power disc stoppers?
#53641 08/31/03 07:40 PM
I think most people called it a "Shot Rod" back then Mack, but you can do miracles with 20 Grand and a roll of bailing wire. I think I will stick with pre 1949 6 lug drums so I don't have to change the wire wheels. That worked great on my 32 Roadster.
Herb
