Posts: 87 |
Has anyone put a tach on a stock 194 with stock gears. I am curious to know what RPM you would be turning at 50 MPH
Dale Duffield Tulalip, WA. 1927 Sports Cabriolet (since 1954)
Posts: 3,542 |
50 MPH? I was thinking (dreaming) about 50 if I took out the 4:11 and put in the 3:50. Maybe I'm too conservative, is 50 ok with the 4:11?
RPM's I would guess would be fairly high, would like to know also. Good question.
With a 4.11 rear end and 19" wheels it should be about 2500 RPM.This is auuuming that the speedo. is acurate at 50 MPH.
Posts: 2,157 |
gator & chevgene, I've driven our '30 at speeds of 50 or just over (assuming our speedo is accurate)...is this not recommended?..  epi
Should be safe if engine is in good condition-ie no loose bearings.Wouldn't recommend too much over that for long distances.
Posts: 87 |
I normally travel at 40-45, I have hit 50 downhill, but those skinny tires and flexible frames do not really like it. I am guessing the RPM is around 3000 by engine sound. I was just curious.
Posts: 3,542 |
Since Florida is flat (hope the icecap doesn't melt too much) and no mountains to climb, I thought a 3:50 would be the way to go (no pun) for me. 50-55 MPH for shorter trips would suit me just fine.
I don't know about getting on the interstate, it scares me now in my daily driver.
Posts: 421 |
Posts: 3,542 |
For my '32.
1918 RPM's for an 18" wheel, 3rd gear, 50 MPH, w/4.11 rear?
1633 RPM's w/3.50?
Is that right?
Is 3rd gear "1 to 1"?
Posts: 421 |
Posts: 421 |
Posts: 1,919 |
Just a side note!
I noticed that everyone was talking about the 3.50:1 gears that Larry makes. I was talking to him about 3 months ago and he said that the next time he makes gears might be the last.
Hum.......it sounds like everyone that needs those gears should get their orders in so that they won't miss out on the next run! :eek: :eek: :eek:
You can calculate from charts all you want.Piston speed means nothing on a 1930 Chevrolet as the engine can't turn fast enough to have a piston speed problem.The lubrication of the rod bearings and pounding of the mains (with no oil pressure except to the center)is the limiting factor.The end rod bearing troughs get only the oil leaked thru the end mains.Looking back at the proving groung figures for a 1930 50 MPH is about 2458 RPM.60 MPH is a little over 2930.The top speed is listed at 62 MPH.-which would be about 3000 RPM.I know they will go faster down hill or with the wind ,but not for long.The 3.50 gears will give about a 13% reduction in engine speed.That would give a 2565 RPM engine speed at 60 which is still above the safe RPM range which I would consider about 2500 max.A little highr RPM would be safe for a '32 due to the improvements in oiling.....Wheel and tire size.at 50 MPH the 1932-33 engine is turning at 2495 with 5.25 X 18 tires.Engine speed for the 1930-31 is 2458 ---both running a 4.11 rear end. When you get to 6.00 X16 tires its over 2500 RPM.
Posts: 2,157 |
dog & chevgene, I agree that the engine seems to cruise happily at about 45mph...the fifty-ish speeds are occasional, going downhill, & while not paying enough attention... thanks for your comments,  epi
Posts: 421 |
Posts: 3,542 |
Johnny, So if I understand what you said, if I drive like a have a 4.11 when I have a 3.50 it would be even better for the motor.
JYD, where can I go to read the article? Is it on line?
I would be happy to pay for (or send a SASE) xeroing and mailing, if someone was willing to copy and send it to me.
Posts: 3,542 |
Posts: 2,073 |
Any speed over 40 is too fast for a car with machanical brakes! Specially if your free-wheeling....
Chat Group Chapter Member Current rides; 1968 Camaro rs/SS 350 4spd 2000 Blazer LT 2005 Malibu Maxx 2007 Acura TDX Last total restoration; 1932 Sport Coupe
Not really. If you have the correct linings for the mechanical brakes on your car, and your brake system is as it should be with the brakes properly centralized and adjusted correctly, going over 40 is definitely not a problem! I have several friends who drive their cars 60 to 65 miles per hour. One is a 1931 Chevy coupe (with overdrive) and the other is a 1930 Chevy sport coupe with the 3.50 gear set. I have ridden in the two cars (even driven the 1931 coupe) and both cars stop on a dime at those speeds because they have the correct linings, and their brake systems are up to snuff. :cool2: Free Wheeling, now that's another story. It's dangerous to drive a car in free wheeling, and that's why it was outlawed in 1933-34. :eek: :eek: :eek:
Posts: 2,157 |
and the correct linings would be?..  epi
