Posts: 35 |
Before I twist and break off the bolts and set myself back a few hours. Is there a thermostat in the neck housing of 28 Coupe. :eek: Thanks
Posts: 217 |
Technically, there should be. In most cases, it has been removed. You should be able to peek down into the neck with a flashlight and see if its there. I don't know the correct temp to use though. Others will probably chime in soon. Good luck on your project! -R
Hi dads 28, The outlet is much larger on the 28 engine than previous 4-cylinder engines. This was to provide for a thermostat. It is held in position by a "U" shaped bracket and secured with two brass screws. The thermostat is 145 degrees. Unwittingly, most thermostats have been removed thinking it would make the engine run cooler, when just the opposite is true. With the thermostat installed the engine runs at a more stabilized temperature and is LESS likely to overheat.
Posts: 282 Likes: 2
Posts: 282 Likes: 2 |
Now the question - Can you still purchase a thermostat to fit into the neck of a '28? I have seen the ones that go on the hose but do not want to go that route.
Mike Quezada (559) 250-5427 mike.quezada@M2ProSol.com
Hi Qman, Standard Chevrolet thermostats fit nicely in the special housing for the 28 Chevrolet. Obtain the lowest temperature thermostat you can find such as the 145, 160 ect. (That is assuming you can't stumble on to an original and functional thermostat).
Posts: 239 |
Hi dads 28 I took a picture of the housing and various parts that I used for my 28. Click on www.cybersurfers.net/~herb/rmo2.htm I drilled a couple of #20 bypass holes on the rim of the thermostat to assure circulation. The original had one small hole. Herb
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I have a bunch of those low temp. thermostates (gm) if any body needs them. E-mail me And the other 1928 parts
Posts: 35 |
Well I BROKE the bolt anyway. It was 50% rusted through. But the stud did come out of the block. And guess what, no retainer, no thermo. Oh well whats another nite in the shop anyway.
Posts: 11,162 |
Hey, Dad's 28 A night in the shop is like a day in the Marine Corps: "Every day is a holiday, every meal is a banquet, I love the Marine Corps! " A. J. Squared Away, God Bless America! and Remember the ALAMO!
