Posts: 11,162 |
I guess I could have placed this in the "Parts Wanted" forum but I really would like to know if a vendor sells these decals? :confused: I have seen them on engines on ebay and other places but haven't seen them on any on-line catalog. Anyone know where they are available? also a stoplamp switch for a 28? Moderator: If you think this topic needs to be moved, have at it!
Posts: 27 |
Hi I buy very nice decals from Gary Wallace http://www.cybersurfers.net/~herb/gary1.htm $ 5,00 each Regards Arvid
Posts: 11,162 |
Thanks, Arvid, I don't have a printed catalog yet, and I didn't find any on the online catalog, Gary e-mailed an update before going on his vacation but I couldn't read anything but the first page. I will call in a week or two.
Posts: 239 |
Hi Mr Mack, I as one moderator don't see a need to move this topic, actually I want a set of decals myself. I'll simply enhance your question by asking, when I get them where do I put them ? From my repair manual the oil filter decal goes to the front unless you put it at the back. The Air Filter decal goes right where you can see it unless you mount the filter so you cannot see it. I'll follow up with Gary and see to it that the decals are added to the on line catalog if they are available. For the stoplight switch as Chris Cufr suggested in an adjoining topic for the interim you might use a Model A (Ooops ) Switch as shown in Snyders Catalog on page A-44. it's in the Sources Section of my Website www.cybersurfers.net/~herb/sources.htm Try Clicking on the above now. I don't know what went wrong the first time. Herb
Posts: 11,162 |
Ok Herb, thanks. The pics I have seen is of a small round AC decal that is seen from the passanger side in the center of the aircleaner and oil filters, I have a 1951 stoplamp switch I think I can rig to work. Gary emailed an update for the catalog but my M.S. Word didn't work very well, just got the first page and a lot of gibberish Square characters, pages full. I was going to wait till after the 15th (when Gary gets back) to order.
Posts: 239 |
I also just noticed that the Filling Station carries switches for 42-50 and 51-54 which are mechanical type switches that could probably be adapted. See www.fillingstation.com Page 136. Oh, I just rembered when Gary has E-mailed me updates they are in Excel ( ie MS Works ), you might try that. Herb
Posts: 316 |
Mr.Mack, the the airbreather decal is also available from I & I Reproductions, Inc in Paramount, Ca. Ph # is 562-531-8117 they were working on a web site. I think they were about a $1.00 ea.
See the USA in a Vintage Chevrolet
Posts: 239 |
Hi Kirk, I&I 's Web is at www.iandireproduction.com It's been under construction for some time but tells how to order their catalog. Herb
Posts: 316 |
Herb, thanks for the info. How's the project car comming along? Kurt Reynolds, our asst. director made a visit to Tom's place and had a great time looking at the collection. He also bought one of the overdrive units for his 27 Landau and is in the process of installing it now. I look fwd to seeing how it works out. Kirk
Posts: 239 |
Hi Kirk, The 28 is running good, I still have to clean the scale out of the Gano Filter regularly or it starts running hot. With the 189 cu in engine and OD I can hold 70 on level ground but I'd feel safer in a go cart !! I just had my two 28 Blocks cooked and hot blasted but that's going to take a while. I'm also just finishing a 28 Head with small block V8 Valves and cleaned out ports which should help the Vintage Weber Cam a little. I recieved a question from Curt Reynolds this weekend and told him how to get the OD Instructions at www.cybersurfers.net/~herb/overdrive.htm and told him who shortened my driveshaft. Also Gary W says he does have the decals, I'll pass the information on as soon as I get it. Herb
Posts: 316 |
Gary, glad to hear that Kurt got the info from you on the OD and hope his works as well as the one you have installed. Thanks again for the I & I web info will stay in touch. Kirk
