Posts: 217 |
Anyone try this tip? "A method of determining the speed of the engine when idling is to grasp one of the valve lifters between the the thumb and finger and count the number of times the valve lifts in twelve seconds. Multiply this number by 10 and the result is the number of revolutions the engine is turning over per minute." Much better than my old method of grabbing the spark plug wire and counting the number of times I get shocked over 12 seconds.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Yes, this sounds like a great poor man's way of figuring out the revs.... but I sure would like to watch you do it the older way!!!
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
Posts: 1,178 |
In 1950 I worked with a guy in a service station that just loved to share this information with any one walking by, he would just grab a spark plug wire grab you and let you count the rpm for him. No rubber boots then!
Posts: 39 |
Don't be such a woossie. The ABSOLUTELY best way to determine rpm is to shove your arm into the radiator fan, count the number of seconds before you black out, then have someone else multiply that time by the time (in months) that it takes you to recover. I'm told it works all the time.
Posts: 84 |
HEY J.Y.D. WOULD YOU HELP ME TIME MY CADILLAC IT IS A CHEVY AND IT DOES RUN A LITTLE ROUGH! P.S ITS GOT A V-16. I PROMISE TOO LET GO OF THE LEASH WHEN IT'S TIME!
N J HORST
