Posts: 154 |
Can someone tell me where the spring bracket for the cowl vent adjustment latch gets mounted? All the pictures I take are never enough.
FDNY
Posts: 1,919 |
On the original cowl wood for my Phaeton there was a notch for the bracket, only problem was the bracket was not screwed in that notch. :confused:
Posts: 154 |
Thanks for the advice on the spring bracket. I can see with some careful repositioning of the wires how it would work.The bracket and spring however , only have a normal drop of 2 1/2 ", and 4" is required to reach the tensioning latch. I'm thinking of replacing that spring with something longer or softer so as not to pull the screws out of the wood.
FDNY
Posts: 1,919 |
Hey Skipper! Where did you come up with a free length?
Posts: 1,919 |
Cool! I need that information. Can you tell me the wire size and OD of the coil? Also what kind of hooks? :p :p
Posts: 154 |
JYD-This site is really great, I would be in trouble without it. The spring that was in there was about 2 1/4" and very stiff. I did replace it with a softer one about 2 3/4" and it works fine. My next problem is where to run the armor covered wiring harness through the body to the tail light bracket. Is it posible that when I welded in :confused: :confused: new body panels (before putting this project to rest for the winter)I didn't notice a hole? By the way I went through all the G & D mags for the past few years and there are no revealing :confused: pictures. :confused: :confused: :confused:
FDNY
The gas gage, tail light wires run along the drivers side inner frame not inside the body. There are holes for the stove bolts and wire clips.
Posts: 154 |
There is a hole in the chassis through which I can run the wires to tail light arm. But, what about the armored covering, it's slightly too large to go through the chassis. I could enlarge the hole if this is where it's suppose to be? :rolleyes:
FDNY
There is no armored (metal) covering. The wire is covered by a woven cloth loom. The armored covering was used in 1929 and 1930 on the tail light since the wiring harness was exposed. Also, the wiring to the tail light does not go through a hole in the frame. It bends under the lower frame rail and then goes to the tail light support bracket inside of the rear fender. :eek: :eek: :eek:
Posts: 1,919 |
Hey Skipper!
I have a problem with that last post! I've looked at Bill Barkers 31 coupe and it has a SS conduit on the tail light wiring. Also Bill Barlage 32 Phaeton has the SS Conduit! I have the original wiring from my Cabriolet, I'm going to look at it later when I can find it.
Posts: 1,919 |
Maybe we could get Bill Barker to take a picture for us? I'll see about scanning the picture that I have.  Just one more mystery that the chat page will solve!
Posts: 2,073 |
Thanks JYD for that info. I wondered about it myself. My 32 SC had a wire loom around the wires. The loom was in threads when I got the car, and covered in dirt. I found a SS conduit from Harley Davidson and it fits thru the hole in the frame, and in the bracket. I have to paint the fenders soon so I can change it to a woven loom. The SS looks cool,  but thanks for the info.
Chat Group Chapter Member Current rides; 1968 Camaro rs/SS 350 4spd 2000 Blazer LT 2005 Malibu Maxx 2007 Acura TDX Last total restoration; 1932 Sport Coupe
Posts: 154 |
That explains it. My replacement fenders do not have that tunnel. I'll do the best I can and maybe someday fabricate something. Thanks to all. :arrow: :arrow:
FDNY
Posts: 154 |
p.s., one last question ( I hope ) regarding the wiring harness. Where does it pass through the fire wall, from behind the dash to the chassis? I thought I had it figured out but when I went to install the free wheeling cable there were no more holes. :(
FDNY
Posts: 154 |
FDNY
At least some 1931 models came with armoured tail light wires. It was not SS but zinc plated or galvanized steel the same type as '29-30. I believe that you can get the same type and size (two wire) from Rhode Island Wiring Services or from Y&Z in Redlands, CA.
