mikki71 Offline OP
Hello Guys.
Can anybody tell me if the consumption of fabrics to my Chevrolet Std -35 4 doors same at Chevrolet Master -35 4 doors?
Thanks,Mikael
NO-The Master had a plain brown mohair.The Standard had brown with a slight pattern (looks like lines) in it.
Neither one can be found today.With the Master you can come close with what is available from Hampton Coach.....For the Standard you would need to use the same material as the Master.
