GOTTA31 Offline OP
When I bought this car, the guy told me it had never been driven in the rain. Well, I know why!! The control handle for the wiper won't budge! So here's my question:
After I remove the plate around the knob and remove the 4 screws that hold the fabric strip the plate rests on, what am I going to find behind the fabric?
Is the wiper control knob attached to the motor and does it come out when you remove the motor? I can't figure out why its frozen stiff and so I'm wondering what "little Jack Horner is going to find when he sticks in his thumb!!" Is he going to pull out a nightmare??
Gotta31 :confused: :confused: :confused:
The 1931 wiper knob connects to a long goofy looking rod, which in turn connects to the wiper motor. laugh laugh laugh
GOTTA31 Offline OP
JYD--So it comes out as one whole unit when I remove it from the exterior of the car.
If I'm hearing (reading) you right.
Gotta 31
no the rod goes through the header board . really you need to contact the 31 ta he has the rods and can tell you how to get them in and out the rod can not be bent or it wont work and there is a trick to getting it in or out . hope this helps
Pushrod is correct. The rod cannot be bent so be careful!
:eek: :eek: :eek:
GOTTA31 Offline OP
Pushrod:
What did you mean when you said "contact the 31 ta"
Whats a ta? :confused: :confused:
GOTTA31, "ta" stands for technical advisor. For
1931 I think it is Bill Barker.
yay 1929 Chevrolet: Most outstanding Chevrolet in Chevrolet history! yay
1929 Coach
Capt. Harley
GOTTA31: You are a member of the VCCA and you don't know what a "TA" is? Holy Cow! bigl bigl bigl bigl
Captain Harley: Bill Barker is not the 1931 "TA". Billy Barker is the Administrator of Chevy Chatter. The "TA" for 1931 is an old dude in Texas known as Chippy Dippy.
wink laugh
JYD, I stand corrected! :stressed :eek: :p
:love: 1929 Chevrolet: A Six in the price range of a Four! :love:
1929 Coach
Capt. Harley
If the knob and rod is stuck, I would first suggest removing the wiper motor by removing the vacuum tube and two screws holding it to the bracket on the outside upper windshield panel. That way you can find out if the valve on the wiper or the rod pivot or both are stuck.
GOTTA31 Offline OP
Its great to have all you genie's to help us "newbies"!
I'm going to remove the motor from the outside first and take a look. If I see a bomb about to explode, I'll put everything back and talk to the "TA". Chipper, thanks for the advice.
JYD----I am SO-O-O-O-O-O EMBARRASSED AND RED-FACED that I was verbally spanked on the chat!! Your are such a mean man!! :p :o :o :p
GOTTA31 Offline OP
Chipper:
I removed the ww motor. I now understand what was being said about that control rod! Anyway, the motor seems to be in working order when operated by hand. The gears moved freely. The part of the wiper the control rod hooks on to moves probably a 1/32" or 1/16" at the most. I don't know if thats all thats required to actuate the wiper or not.
The vacuum line to the motor was not connected but was resting behind the motor so I couldn't see it until I got a light in there to look. It had a screw in it to keep it plugged up. I tested the line with the motor running and there is vacuum at the hose end. However, when connected to the wiper, a hissing sound can be heard. I looked at the hose end and its not split. I can't tell where the leak is but its got to be coming out of the ww motor someplace.
Any thoughts?
Gotta31 :confused:
GOTTA31: "Your are such a mean man!!"
Tsk, tsk....wrong again! I'm a dog remember? You know....a mangy old mutt! bigl bigl bigl
Your wiper motor is probably leaking around the shaft. Sounds like it might be time for a complete rebuild.
:eek: :eek: :eek:
GOTTA31 Offline OP
I can't help it. I had a "senior moment"...DOG!!!
YIKES!! curse I told you guys I was problem rich!!
Gotta31
GOTTA31 Offline OP
I notice the Filling Station does not sell repair kits for ww wiper motors, but they do offer a rebuilding service for $95. Does anyone know someone who sells gaskets and rebuilding kits for these? If not, I guess 95 bucks is the best I can do.
Gotta31
For a repair kit or a complete rebuild, go here:
http://www.wiperman.com/
laugh laugh laugh
GOTTA31 Offline OP
JYD--Great place to get if rebuilt. Sounds like they do a really good job. I'll let the experts handle it.
Thanks, JunkieDog!! laugh wink
Gotta31
You bet and Bow Wow back at ya! talk talk talk
You can buy a kit from several Model A part suppliers. I use Snyder's Antique Auto Parts in Ohio or Mac's in New York. They can be googled.
GOTTA31 Offline OP
Thanks, chipper!!
I'll Google 'em up!!
Gotta31
