Looking for a pair of good used original nuts for the 216 valve cover brass hold down brackets.
Support The VCCA!
If that is a picture of what you are looking for, most of us have never seen an aftermarket attachment like that. If you have the rest of it you are probably going to need to have them machined at a local shop.
In my 20 years of VCCA and ChevyTalk, I have never seen those brackets.
In my over 80 years of Chevolet experiance I have never seen it also.
Check this article out from Jim Carter Truck Parts:
https://oldchevytrucks.com/blog/2010/02/216-oil-leaks/
In over 50 years dealing with Chevys Iv never seen thoes before! You might try Ace Hardware, they should have a good selection of brass nuts.
1932 4 door Special Sedan 1916 490 Touring
