1941 Master Deluxe, 216, 3 speed.
I have not changed any of the linkage for the shifter. I can get it into and out of gear. I have driven manuals for some time but always assumed it way me with the shifting not being 100% smooth between gears. Occasionally I may find it difficult to shift between 1st and 2nd, rarely between 2nd and 3rd. What in the linkage should I look at for wear? How much play is OK? The linkage has never been adjusted by me and since I could get it into gear and to shift I just thought it was the cars personality.
I saw these on EBay and was wondering if these were a good idea?
Shift AdjustersIf this is just the way it should be then I am fine with that. If it should be better than I will try and make it so.
