Posts: 66 Likes: 1
Posts: 66 Likes: 1 |
When I purchased my 39, it came with additional parts. The carb. on the running motor is stamped W1, this carb only has two screws holding the cover for the accelerator pump. The spare also stamped W1 has 4 screws holding the cover. Wondering which is the correct carb for the 39. Thanks, Tom
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
Based on what I know the 4 screw cover was introduced in 1937.
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
Hi Rusty I believe you are absolutely correct. 👍 My "go to" guy for information on carburetors is Jon the CarbKing. And this page on his website is my favorite place to go for information on identifying Carter W-1's, and figuring out which carburetor a car should have: https://www.thecarburetorshop.com/CarterChevroletW1.htm
Ole S Olson
The 4 screw will be correct for 1937 and up. The carburerors for 1938-1940 are almost the same and the throttle bore will measure 1 7/16" The W-1 with a 1 1/2" bore are for 1941 and up.
