I read in a forum post to drill out the timing gear oil fitting to 1/8". My question is do I drill the small hole on the side or the hole down the center or both?
Drill the small hole to 1/8" but make sure the other hole is at least the same. If you drill the lengthwise hole dont overtighten the fitting into the front plate. Tony
I should add to make sure the small hole points to the junction of the 2 gears. Tony
