WI_Jeff Offline OP
This is more for General information. Rear Huck Brakes. When ordering wheel cylinders, make sure the attachment bolts are the same as you have. I did not find anything about this when I ordered mine and the bolt holes are in the wrong place. They are even with the bleeder. The one that I need has the bolt holes even with the line input. Look at the picture and you will see the difference .
Good information, thanks for the tip.
Are they NOS or new repros? Did the vendor have the correct wheel cylinder for your car?
