Hello folks!
I am in the process of keeping my 1941 Chevy Master Deluxe in as original shape as possible. Currently my focus is on the transmission - I think it has quite a bit of wear as the synchro when shifting from 3rd to 2nd doesn't seem to work terribly well. It grinds unless I double-clutch. Oddly enough the vacuum-assist shift is working well, though ultimately I chose to disconnect it.
So, I am faced with the decision to either restore/rebuild the existing transmission or else install one of the two other transmissions I have which I believe are the 216 variety.
Here's the issue: I seem to recall finding a website which talked about the various years the 216 transmission was made and that there were some fairly significant differences in performance/reliability. Unfortunately it's been several years since I found that website and I cannot find it any longer. Can anyone point me there?
Finally, the extra two transmissions that I do have show some serial numbers. They are "691193 GM20" and "891199 GM12 J2". The latter of these two also has the vacuum-shift module attached. I'm wondering if there is a way to decode these serials to determine the model year? I seem to recall the above website I mentioned allowed you to do that too.
Thanks for any help that you can provide!
