#489093 01/25/24 02:56 AM
Lou Offline OP
. What size Stamping Punch is used on the Vin Plates? . 1/4" seems too large. 1/8" too small. I can not find 3/16" stamps for comparison. The first number is the factory location. (2 = Tarrytown, NY ) Next alphabetical letter or two is year and model. (LM = 1927 One Ton. ) Is there no month code on 4-cylinder Chevys? Next four numbers is serial from that factory. Could there also be five numbers in the Serial?
. Thanks, . Lou .
Lou #489095 01/25/24 04:41 AM
There isn't a month code.
Yes there can be 5 numbers in the serial number.
My '25 ID # is; 2K63173.
Steve
Lou #489096 01/25/24 05:34 AM
Lou Offline OP
. Hi Steve, . Thanks for info. I'll stamp accordingly.
Lou . .
Lou #489531 02/10/24 03:30 PM
Lou, back to your original question, what size punch
Mike Quezada
(559) 250-5427
mike.quezada@M2ProSol.com
Lou #489533 02/10/24 04:58 PM
Lou Offline OP
. Hi Mike, My 27 has nine digits in the ID number. Quarter inch was too large. I ordered 3/16th from McMaster-Carr and it was shipped the next day. I lined all the digits up next to the plate for alignment reasons and there wasn't enough room so I used eighth inch and it fit including the space between model number and serial number.
. Thanks for asking, . Lou
Lou #489689 02/16/24 07:31 PM
Lou, did you line up all the dies and struck it in a single hit? I cheated on mine, i went to a trophy shop and had them engrave it
Mike Quezada
(559) 250-5427
Lou #489691 02/17/24 12:25 AM
Lou Offline OP
. Hi Mike, I'll send you a personal email with more detailed info. .
Lou . .
