#488973 01/21/24 10:16 PM
jp49 Offline OP
Does the horn mount on valve cover 1927 capital?
jp49 #488987 01/22/24 11:15 AM
It mounts on a bracket which is mounted to the exhaust manifold.
Steve
jp49 #488990 01/22/24 01:32 PM
Lou Offline
. Picture #1 is mounted on exhaust manifold. Pix #2 is truck mounted on firewall. I notice there are two style horns. .
. Lou .
jp49 #489000 01/22/24 05:15 PM
The correct horn for a 1927 is a Klaxon 8C that mounts on the exhaust.They can be bought on Ebay or from Earlychevyparts.com. Here are a few pictures of them.
Steve
jp49 #489002 01/22/24 07:18 PM
jp49 Offline OP
Thanks, I have horn and bkt but 28 head and fins on exh manifold.
jp49 #489007 01/22/24 09:03 PM
The 1928 horn fits on the drivers side frame across from the oil fill tube. Here is a picture of the mounting bracket you will need. They cost about $40. The Klaxon 8C is correct for 1928 and '27. Also I found a picture on line of the horn location. I hope this helps. Good luck.
Steve
jp49 #489047 01/23/24 06:14 PM
When I fitted a 1928 head to a 1926 car I made a new bracket like original to fit rear of 28 exhaust. Worked great, but here in Australia 28 exhaust manifolds are different so may not work on yours.
jp49 #489052 01/23/24 08:56 PM
jp49 Offline OP
Thanks I can make that work.
