. The same diameter pipe uses inside diameter and if it's called tubing, it uses outside diameter. IE; half inch pipe is 5/8" tubing. In the picture of a heater valve, the pipe threads are 3/8" pipe and fit 1929 - 54 water pumps. I believe that the 1955 - 63 used a half inch pipe thread. The smooth end is actual 5/8" OD, excluding the bead so fits a 5/8' ID hose. [b]IE: use 5/8" ID hose.[/b] . . Some folk say it originally used red hose. (??) . . Lou . . .
Lou, I believe he's referring to the hoses connecting the heater/defroster fan to the windshield outlets. To the OP, I think I have a piece of hose left over from when I added the heater to my 38. If no one answers your question soon remind me and I'll go measure it.
