Posts: 10 |
need a new fuel pump and like to get one without the glass bowl , electric ones are 12 volts and I like to keep car 6 volt , what are you using ?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
The Filling Station just got a batch of fuel pumps in that have the sediment bowl. They may have alternatives without. Give them a call.
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
p.k.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Bob Marx at Marxparts in Wisconsin can probably help you. Look for Marxparts here on chat or call him at 715 652 2405.
Posts: 470 Likes: 33
Posts: 470 Likes: 33 |
They must be available. My 41 has a manual fuel pump without the filter on it. It was that way when I got the car. The filling station has one with and on without vacuum: https://store.fillingstation.com/detail/FS-215/Chevrolet_19371951_FUEL_PUMP_NO_GLASS_BOWL.html
Posts: 18 |
I used this one from Advance on my '50. Works great. No problems...Spectra Premium Fuel Pump Part # SP1065MP
The original style had the glass bowl with a built in filter. The no-glass bowl type has no filter and was first used in 1955. That is because the 1955 had a filter in the gas tank.
