Chip is right on the mark, any leak or movement will cause it to quickly fail. One more question. Are both pipes the same? I have seen some pipes have an extra sleeve in the center that gives support and containment of the actual gasket. It protrudes up through the doughnut into the base of the exhaust manifold and has a flared out shoulder where the doughnut sits. Looks similar to a double flare used on brake lines.
If the pipes do not have that it might be something to build and try.
