Can someone help me figure this out? i am needing to get some engine parts ordered to get it running. I recently bought a car titled as a 1927, but some things are not making sense??? Engine has a two port exhaust head (28 and later), but has exposed push rods (27 and earlier) Engine block casting number is 348532, serial number is 4556969. Casting has a bowtie with 17, below that is E298 (Made 5/29/2028) Head has a casting number 348540, E288 (made 5/28/1928 I'm guessing) with a 7 below this. Plate on the firewall shows job no 7220, Body no S15019. Vin Plate on passenger floor shows Model Capitol, Car Number 3AA52992
Pistons are not cast iron or metal also.
Wheelbase is 104 on the driver side and 102 on the passenger, not put on the lift yet to look at that. Any direction to look at this would be helpful as well.
Thanks coachman. Looks like the engine has sleeves. I have a couple pistons and sleeve walls pretty corroded and it will not turn over. Would I be best to put new sleeves, pistons and rings as needed, or bore out the existing and then oversized new pistons and rings?
I think that will be a question for the machine shop. It will depend on current bore size and condition. Standard bore is 3.6875". If you go too large, you will start getting thin between cylinders and experience head gasket sealing issues. Several of my motors are 0.060" over and that doesn't seem to be a problem. Sometimes motors are sleeved because the piston pin gets loose and gouges the cylinder wall.
As accurate as I can get with my tools, I show the current bore is approximately 3.715 and the sleeve is .150 thick. Based on that, it would appear the current cylinder has been bored about 30 over.
