I don't see coolant circulation in the radiator of my 1932 Chevrolet Confederate. How do I determine if my water pump is functioning? Should I expect to see circulation? There is no coolant leaking from the pump and I don't have a thermostat.
Last edited by chevyfleetline; 01/14/24 09:15 AM. Reason: I entered the year and make of my vehicle.
Douglas Shelton
Looking through the radiator top opening it is difficult to see any coolant movement. It is because of the design of the inlet pipe and small opening at the cap. Also until the coolant is heated it will be just above the radiator core in the dark top tank.
is the 32 radiator and such different then the 29-30 ?? I can see turbulence in the coolant as the water pump MOVES a good amount of coolant.
Video of 1929 before rebuild:
other option is you can put in a Gano Filter in the return line to the Radiator and watch the fluid MOVE :)
Thanks for that perspective. Very helpful.
Douglas Shelton
