#488344 01/04/24 11:18 AM
I'm looking for a BW T5 transmission with one of the following model numbers: 1352-108; 1352-110; 1352-145; 1352-146; 1352-033; 1352-042; 1352-043; 1352-058. If you have one for sale, please let me know the condition and your price.
Support The VCCA!
Lou Offline
. FYI: I have been unable to locate a T-5 but did come across a web page to identify numbers with ratios. .
<http://www.britishv8.org/Articles/Borg-Warner-T5-ID-Tags.htm> .
The numbers are on a green sticker that has usually been scraped off. There's also a number on a metal tag bolted where the tail housing meets the case. I don't know how to tell from the numbers where the shift lever comes out. .I don't have much use for a shift lever that comes out behind my seat. The shift lever is only available in the two rear locations in the photo. Compare to the shift lever location of 1938 Dodge in second photo.
. Good luck, . Lou
