dgstarr Offline OP
Why was this offered on AC equipped cars with the standard 61 amp alternator? A 2 amp increase was not much, was the 63 amp more durable? Did it offer a higher output at idle? It appears that the 63 amp one has a case similar to the later 10SI interregnal regulator models.
I think you are heading down quite an interesting rabbit hole with your search I notice that no one has responded to your post on the First Gen Monte Carlo site.
Based on what I know the key is the 7 digit Delco number. That number represents the actual alternator. This would include output, clocking, pulley, and whether or not it is internally regulated.
As you know the K85 was a code for sales orders. I found one post that showed the K85 represented a 37 amp alternator ion a Chey pickup. Those codes were reused from year to year and did not necessarily represent the same option package over the years.
Hope you can find an answer.
THE INFORMATION FROM CHEVROLET THAT i HAVE SAYS THE STANDARD NON-AC IS 37 AMPS.
